Wish you were closer...I could use the spare tire crank.
Pay the shipping and it's urs!
GOOD NEWS!!!!!!!!!!
the dak passed emissions testing today and is licensed. being a 91 this is the last time it will have to go thru the smog test. full steam ahead now. going to be junk yard hunting this weekend for LA front accessories. am going to run the LA timing cover with LA water pump and V-belts. going to run an old school alternator with external voltage regulator. have been doing my home work and looks like the ECM can come out and most of the engine bay wire harness. will being running old school starter relay and voltage reg. got my intake in the mail today too.
Whoa, full stop! I recall that the Dak went to a serpentine setup because the V-belt accessories would not FIT the very-crowded engine compartment!
Anyway: you WANT to keep the serpentine setup...it is vastly superior. (My 95 had its original water pump and belt-yes, the 19-year-old original serpentine belt-until January!) The Magnum water pump is much better (more flow & less cavitation), the later alternator is more powerful & probably more durable. (Any old-school alternator is 30+ years old now.)
Also got a set of 16x 8 durango wheels for $120 for all 4! Gonna run 265/60/16 all way round. They are all over for less then 120 ea
Something else to think about too. They make adapter to install TBI on the carb intakes...
Also, everything I'm reading says you can squeeze up to a 265/70/16. About the same height as the 235/75/15
my dads 2wd 95 came stock with 235's according to the door stickerBut only 4x4's had 235/75's. The 2WD trucks mostly had 215/75R15's.
Oops! Scratch that. Your right. We put 235/70's on it for a wider tire. My bad.
I didnt read every thing but thay look really good lowerd but when you do that you have a tire limt on the the front . One more shot of my old one to show you .
