new distributor vacuum advance causing hesitation
rigrunner
rigrunner
ararat nc
put a new rebuilt distributor in my 318 a while back and have not been able to run the advance because it caused a bad hesitation. finally got around to working on it and found the advance screw in the canister was screwed all the way in so i backed it out a half a turn and it runs alot better and the hesitation is now gone. is there a base setting like how many turns out the advance screw should be turned or is there a procedure that makes sure its correct. thanks.
...................U will have to taylor the curve to ur own engine...............kim........
yup, everyones engine will be a little different...
here are a couple articles that are pretty decent on how to tune your distribitor for more performance.
thanks for the artical. looks like alot of good info. gonna get at it later this evening.
That article that abodyjoe posted should be a sticky, IMO. Great information!
