Your first 2 digits are the plant code(Mound Road) ,the next 3 are the engine displacement(318 cu. in.). Usually a letter after the engine size will denote something special, e.g.- hp or s = high performance, h= hemi, (r= regular fuel).The casting # is essentially the blocks name. The Mopar casting #`s are somewhat enigmatic but as a general rule the first digit denotes the decade that the first casting was produced. 1= 1950`s, 2=1960`s,3= 1970`s and so on. The second digit is the year of that decade that the item was first cast and the last digit will usually tell you if it`s a right hand or left hand part. Even #`s are for the right and odds for the left.So 2458... would have been first cast in 1964. This doesn`t work for all Mopar casting #`s and many of these#`s will appear for a decade or more,but this is the general concept.There`s also a sequential number from a 10,000 day calender as well as what workshift it was, that cast the block.I hope this helps you some. Welcome to the site!
