i assume they are the "standard sized" 7" sealed beams.....just like on my mustang...i never looked close at them, but there aren't many choices in old headlights, so i guess they are.....
anyway....I put Xenon-bulbed assemblies made by Delta in my 68 mustang, and like them very much...they are really bright, and cost me 50 bucks, with the bulbs already in them....
if Mopar used the same 7" sealed beams, they will work (as long as the plug is the same too)...new to mopar as of august, so i don't know a bunch about them yet....
they also have a non-xenon bulb setup...the xenon gives a SLIGHT hint of blue...just enough to make the emitted light white
ahhh....found them.....(800)888-6473
CJ Pony Parts......part # HLA1H, HLA1X, HLA1HC, and HLA1XC
the first two: the H is halogen, the X is xenon(blue)
the second two: the C is for "city lights", which is an extra bulb inside the housing that can be wired separately and can use the supplied white bulb for a "city light", or you can put in an amber bulb and have a blinker or park light inside the headlight.....kind of a "trick" thinbg, i guess......
