Yeah when do we get to see these bad boys?
Really interested to see what he picks up from them. He’s going 1 7/8th? I’ll be running 1 7/8th hedmans, 13.3 compression and a tram but I’ll likely be 3250. Hoping it will run close to the amc at a heavier weight. He’s about 2900 right ?
Yup, sounds like his converter was seriously tight and could easily pick up a tenth or two with that alone. I know everyone is skeptical about how well the stock style head can really run but from what I’ve seen track wise these heads are really really goodi think your very likely to be happy.
That Duster on drag week was almost 3200.
4.10 gear, 727, pump gas, TTI header,1 7/8) victor intake not ported, and the car was only 60 footing in the high 1.40’s from what i understand.
Still went over 132 mph, thats enough mph to dip into the 9’s if he gets it to leave.
I have heard he is having a super victor fully done by Vic. That should most definitely pick the car up, unsure on if he is getting the convertor better dialed in or not
It’s not that I’m skeptical, it’s just that there is really no one out there “Producing” a head like this OOTB with the ability to run in the 9’s or advertising that can can port a head to this level on the same platform cylinder head.
I’ve only seen 3 people claim numbers better than 300 cfm on a Edelbrock head. Hughes engines is one and there head has been reviewed here. The “Did I miss on this combo” thread worth the read.
When B3422W5 kept hammering away that everyone should just get these heads (the ones he is getting) in a fashion as if they are currently available as easy as getting a candy bar at the check out, ii found it hard to believe it was possible to get such a head that easy.
While Rod is on the job doing what he can to get this out. This is not exactly a on the shelf head for everyone to purchase today and have by the weeks end.
The last viable head of this fashion that was capable of being ported to this level was the W5 IF! the head was properly cast. Also as the only head capable of this level when it was new, there was no one else out these making an aluminum head except Brodix in which no one here has seen that particular head perform to expectations according to the flow numbers presented by Brodix.
Currently, the only other heads I have seen capable, would be the upper W series heads and the Edelbrock Victor. But now we are leaving the stock style replacement head arena. And the jist of the thread.
I myself look forward to seeing this all. B3422W5 has been at this for a while now and this should be a good thread. We have a couple of part time and full time active drag racers. When ever they post up changes, especially like this, a big change, it gets exciting for everyone.
Thanks. You never said they were readily a available like a off the shelf head but you did champion them in such a fashion from my point of view, which isn’t a bad thing but they are not, as you stated, a high production head modification readily available like a off the shelf head is, or can be produced in such a major.good post!
I dont know if i ever said this head would be ready “ next week” type thing.
Its a limited production type thing, and was always going to be. Anybody seriously wanting a set should be able to get a set if they are patient. This isnt an assembly line type deal, each head has a narrow pipe its coming down the production line from..lol.
Not sure exactly how many sets of cores Rod has, but i do know he has more than the sets currently in the works that are already spoken for.
The fact is, at 2600 dollars still needing a spring package, its unlikely its ever going to be something the average Joe blow would cough up that much cash for. We have a finite target audience in the smallblock Mopar world.
With the advent of G3 stuff, it makes LA stuff less viable as time goes on, to some. The rest of us become even older dinosaurs
Based on the results i have seen with this head, i think i can say with confidence its indeed a 9 sec head. A typical 3000 pound bracket car with compression and a well specced roller will do that i think easily.
The only reason i am going with these heads is my knowledge that the guy who designed them by himself is an ultra sharp guy who has proven his chops to me time and again.
This will be an interesting comparison regards W5 heads.
Years ago, i had an eddie headed stroker with an extremely similar cam/ compression to what i currently have right now, it ran very similar to what i have now runs.
One winter, i took the eddie top end off( moderately ported eddies), excellerator and TTI step headers off the flattop 416 and sold all of it.
Ryan ported me a set of W5’s( first set he ever did) bought a massaged Victor W2 Brett had used on his W5’s, and bought TTI W5 headers.
I put this top end on my shortblock…Went 10.38 at 128-129 ish( don't remember now) right off the trailer. My cars are never light, because none have fiberglass, all have a street/ strip mission, and all have my 320+ pound butt behind the wheel.
That combo lived until mid August that season, when i broke the Eagle cast stroker crank
I figure if i can get within a tenth tenth and a half of that, with smaller headers, not as good a carb as i had then, and a bit less lift… the new heads will exceed my goals.
I think and hope they will. We will see.
They aren't as big, thats for sure.
I certainly DO NOT want to put words into your mouth or create anything less than what I have seen is an excellent and honest reputation of yourself.
As mentioned before, it’s a damn shame the MP W5 head program went the way it did. As far as I’m concerned, Chrysler/MP got screwed big time and hard as hell from the crap work done for them. It was wrong all day long. On top of that, it all happened before the internet was anything but a new born baby and the corrections to the head never really became known to the public. Confidence in Chrysler/MP’s W5 head fell through the toilet, never mind being flushed down the toilet. IMO, the bad wrap was never over come. A good casting would prove the design and capabilities was more than adequate. IMO, it was a bit expensive though.
The whole W5 program should have been saved and tweaked in the heads ports and intake manifold area.
I hope the ship sails smoothly and quickly through calms waters for you.
if they end at 55cc and are too small for you, i might be interested ;-)
Just Kidding. It´s of great interest what you will find out, if these heads will make good power (more than a proven ported EDE Head or TF190) with the stock architecture then it´s a big + for all of us. Thanks in advance for sharing this story!
Michael
Just curious at to what the power difference was between the 3 heads?the trickflow heads have already been on the same motor as these heads at the same shop/ dyno and made significantly less power. In fact, a set of air wolf heads were compared as well, the trick flows came in last.
To make sure I am clear, these three type heads were swapped onto an existing dyno mule stroker shortblock on three separate occasions at an extremely reputable shop.
So I already know what the results were, hence, made the buying decision that I did. I am frankly glad I didn’t buy the trickflow heads, I was second in line to get a pair.
In addition, I have seen these new heads actually go down drag strips ( even more important to me)
This all said, unfortunately, what I am doing with them won’t come close to fully utilizing them….but I have the option should I decide down the road to step things up.
I should also say, any of these production style heads can make good power, and do. None are dogs at all. Just some are better than others
Dam, straight to the gut punch , hopefully he will chime in!he must have missed your post, that is unless he lying
Appreciate the info, good stuff. I look at it like anything else as in cost vs performance, edelbrocks are now around $1,900 a pair and need work to beat a trickflow. The only other offering in this range is the Bloomer head which looks to be around $800 more when complete so as long as the trickflows don't skyrocket in price they are hard to beat for the value. The main reason I like the trickflow is the the other benefits that they have out of the box including the quality of parts and the improved rocker location. As for me if I was really out to make big power n/a I would be hunting up a w2/w5 style head and not looking back. There is a head being made right now that hopefully will be ready in the next year or so that I am very interested in but the problem is its hard to spend a bunch of money to make power n/a when I have a power adder.I have an apology to make. I stated all three of those heads had been on the dyno. I missunderstood( my mistake)
All three have been looked at on the same bench, and tested there.
They weren’t put on a motor.
The trickflow did lag behind the air wolf and Bloomer heads.
But just the Bloomer heads were dyno’ed. it’s not my place to say how that went.
People can make up their own minds based on what they have actually done at the track.
My buddy did swap his trickflows off for airwolfs and picked up good power doing so.
I confused the two tests. My bad.
Sorry about that.
At the track on the same motor, the airwolfs made more power than the trickflows, the flow bench testing bore out those results.
In case anyone wanted to know why I was so abrasive I owed him a good zing. Like Rambo said “he drew “first blood”. Soon after he admitted to making a “mistake” after getting called out on it. I guess he like me is human after all. Pretty easy to lose a several year friendship when you calls someone a liar.
