redfastback
Don't ask me... my garage is empty
As some of you may have read in a previous thread, I have been working with David Wheeler at Hellwig Products to get an improved swaybar designed for the A bodies. Last year they came thru with the prototypes and I attested and will still attest that they are great bars to run. The install as well as fit and function are all pluses.
This time, they have upped the ante and engineered a new tubular sway bar for the front. With only slight changes that need to be done, the bar feels great. It weighed in at about 9.5 lbs, the previous solid one weighed about 16.5 lbs.(about 40% weight savings). I didn't feel much difference from solid to tubular, due to my heavier torsion bars, but the lighter weight is still a good thing to have.:cheers:
These guys should have a booth at Spring Fling and hopefully be stocked up to take care of A, B, and E body folks. My car will be there and you can feel free to check out and discuss the bars with me.
Believe me,.....I have been taking corners alot faster with more confidence with the front/rear bar setup...:snakeman:
AND I LOVE IT!!!!!!!!!!
