LovetheA's
I thought I would put this out to the experts on the boards. I want to replace my old tired starter with a correct factory starter in my 383 67 GTS dart. Current starter has real hard time cranking when engine hot. I have a couple concerns:
1. Will the factory starter fit with the TTi's I have on the car or do I need a mini starter?
2. Is the correct starter a different unit then was used on small block or slant 6?
3. If so what is the correct part #?
I recently purchased a starter part # 2095219 the case was made 3 67 which would make it date correct for my car built 4 19 67.
I was recently told that all big block starters were different than the small block or slant 6 starters. I was told the starter I bought off of eBay part # 2095219 was correct but I'm doubting that now. An older mechanic I know said that he remembers Chrysler big block, hemi starters being 1.8 hp and the slant 6 or others were 1.5 hp? He showed me an old starter he had laying around and it appears as if the round end on the 1.8 hp is longer than on the 1.5hp. I looked at the one on my car and it appears to be the shorter one. I'm concerned that the longer 1.8 won't fit.
Any help appreciated. Thanks
Carl K
Carl K
