RobbAdams
I installed a RPM Airgap, and K&N AirCleaner with the xtreme flow top, as well as Cutting a hole in my hood to make room. The Engine seems to be missing at the 3500 to 4500 rpm rangem almost like when you hit the rev limiter on a newer car? Does this sound like some sort of lean condition?
It does not seem like pumpshot, as it is fine when I first step on it hard, the condition only arises after sustained throttle mashing?
I'm going to remove the carb spacer this afternoon, and see if that helps.
