New main caps or old
Big Block A body Tech
  1. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    10:35 AM
    I'm in the process of building a 400-471 stroker with the expectation of about 600-650 hp. I was told the old main caps can handle this (street driven only) or should I get new forged caps and have it align bored. Has anyone here used the 440 source caps since that is where I am getting my stroker kit from. I am trying to consider this a one stop shop and get most of my build from them including their cnc ported heads and 1.6 roller rockers. Any pros and cons on this??? Thanks
  2. 1970Duster
    1970Duster Well-Known Member
    6,677
    89
    May 30, 2010
    Local Time:
    8:35 AM
    I'd go New forged caps and a stud girdle, and call it done.
  3. 66V100
    66V100 Well-Known Member
    68
    1
    Sep 26, 2011
    Oviedo FL
    Local Time:
    10:35 AM
    I would go with aluminum main caps.
    The steel on steel in stroker apps puts a lot of stress on the main webs, and transfers it to lower cyls as well. The aluminum caps will "soften up the hit." alum caps flex, steel caps just snap. just my .02, am sure some that havnt seen broken steel caps or broken lower cylinders (esp on major thrust side) will dissagree. The new caps will need to be sized to the block.
  4. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    17,752
    5558
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    10:35 AM
    ................I vote 4 alum caps also...............kim.........
  5. crackedback
    crackedback FABO Gold Member FABO Gold Member
    18,837
    3241
    Aug 7, 2005
    92201
    Local Time:
    8:35 AM
    At that level aftermarket caps aren't really needed. If you planning on stepping it up and going over 700hp on a B block, then start looking at main caps.
    Here's another thing to chew on. If you do go over the 700 mark, start thinking about an aftermarket block. I spent a good chunk of change on alum caps, machine work on a 400 block. It would have been a bit more to get a better piece to start with.
  6. JohnRR
    JohnRR This space for Rent
    751
    10
    Dec 4, 2008
    Local Time:
    11:35 AM
    Buy something other than their rocker arms .
  7. moper
    moper FABO Gold Member FABO Gold Member
    15,849
    1965
    Dec 27, 2004
    eastern CT
    Local Time:
    4:35 PM
    You dont need caps. Have the mains studded and align honed and run it.
