4spdragtop
Welcome from north of the border.
going to be doing some bench racing?
definitely cheaper! really like set up with backyard. that's hopefully the next project on list.Ha!Ha! Actually cutting 46” out of it to put in a nook in the entry way for a place to sit down to take off or put on shoes. I have both ends, so I may make a bench out of part of what is left. Should be working on the Duster.going to be doing some bench racing?
thanks 69conv! same heads from the last 2 years but had them cnc'd,, same with intake with some plenum work. comp cams hooked me up with new bumpstick. a little more compression and going to 850 carb. game plan is to break into 9's with magnum motor. real street car!!Meanwhile, back at the ranch. Looks like a pretty stout top end, is that your new heads? With the upgrade i guess you're planning a cam to take advantage which means your intake/carb may need upgrading too. Do you have an overall game plan figured out? Personally I'll never see the kind of build you had, so I'm kinda living your build.
