tntperk
New Mopar 360 for Sale
For Sale a Mopar Performance 360 LA Series (pre-Magnum) short block. New never assembled. It has the factory Crankshaft, 9.5 compression Pistons and Mopar Performance camshaft Part # P4876908 .509 Lift, 292 Duration. Should run well on pump gas.
Note: This block is an early 90s casting which is drilled and tapped for the factory roller lifter girdle if a swap to a roller cam is desired.
It also comes with new Vibration Damper, Oil Pan and Windage Tray, Oil dipstick and tube. All for $1,600 dollars.
This is located in North East Connecticut I will not ship it. If you want it come and get it.
