New Mopar power steering leak
pishta
I know I'm right....
Tustin, CA
2012 Dodge caravan 3.6 FFV...pretty good power steering leak passenger side at the pump. What are chances its the pressure side or the return side? Maybe the fitting? Just started yesterday, 6" puddle overnight...don't even know how to attack this. Advice, warnings? :BangHead:
Man, as much Crazy Genius stuff You've Done? I'm behind the times I guess... I'm sure if You're Asking, it must Be a PiTA. Does it have hoses?
Hey you probably want to take the undercarriage cover off or maybe go through the side wheel well if it's what I'm thinking
yeah this modern transverse mounted crap is a ***** when all the pulleys are behind the tire! 2007 almost had to pull the engine to get to the water pump.
I need to replace the PS pump in my 2006 GC. It is so tucked up in there I have put it off for over a year.
The FSM has the procedure.
Good luck
If it leaks static, it's probably the return line.
Look at the lines where the clamp holds them down by the steering rack. They rot out there because of the clamp.
