autoxcuda
- Joined
- Apr 6, 2007
- Messages
- 8,838
- Reaction score
- 3,792
I tested out the MSD E-curve and the Denso 102mm alternator in the temporary 360 motor that is in my Barracuda last Sunday.
The MSD E-curve was really too tall for an 67-76 A-body with 3 speed wiper. The wire boots are only 1/2" away from the wiper motor housing. To remove the cap or distributor, you have to remove a couple wires to get access. Also this is very close to shorting out a plug wire, IMHO.
This distributor housing is special to the Small Block mopar, all they had to do was make it 1/2-1" shorter. Completely stupid that MSD does not R&D thier parts enough to spot something like this. IMHO, they just pissed off 20% of thier market (50% A-body, 1/3 of that w/3 speed wipers)
I've seen ARengineering run an E-curve on a 68 Valiant with 2 speed wiper motor and it was OK clearance.
Timing was as solid as you could get with 20K mile small block timing chain and no chain tensioner. The wiring was simple and very clean.
