I would like some input from the members here.
We are considering offering a upper and lower control arm exchange program.
Product 1 will be stock upper and/or lower control arms, they will be blasted and painted, new ball joints and Poly bushings ready to bolt in.
Product 2 will be with a reinforced lower arm as above.
Changing a-arm bushings and ball joints without the correct tools is a real problem for most home enthusiasts. Running a BB in an A-Body without reinforcing the lower arm is probably not a good idea. You can buy the reinforcing plate and if you have a welder you could do it yourself, without those tools it can really be a hassle.
We will offer them as an exchange program with a core charge, which we haven't determined yet, we'll see what it costs to buy the initial inventory.
We're also working on Moog to be our supplier for the other components like center links and tie rod ends so you'll be able to rebuild your entire front end as a bolt in do-it-yourself kit.
I'd like some feedback as to your thoughts as to the marketability of this product and would you buy A-Arms rebuilt and ready to go or do you prefer to do it with a hammer and bleeding knuckles?
Thanks Guys
Don
Thanks Guys
Don
