New Rear leaf install issue
rlipp69
Active Member
Frankfort
Just installed stock new rear leafs on my 68 fish . It is way to high in the back. Whats the best way to fix this? Lowering kit. Take them off to get de arched?
The lowering front perch will get you 1", and the cheapest way to go
Yes, invert the front spring perch.
^ x2. Mine did too
I took my stock springs apart and media blasted each leaf, repainted installed new inter-liners. Now my car is sitting way to high in the back. I'm thinking the media blasting work-hardened the metal.
Also, new springs do settle after a while. Mine did on my 69 Dart.
I hope you're right.
Thanks for the tip. I might try this.
take them to a spring shop and have them de-arched.Don't let them talk
you into disassembling them and doing each leaf individually.
Pinch them assembled ...should take about 1/2 hour
