I have a small block Lunati circle track cam that I had reground by Oregon Cams for my street car. I still think it needs about .100 more lift after talking with Brian at IMM Engines. IMM will spec a new cam to go with their Aluminum heads so this cam is to small for 285cfm at .600". I can provide the cam# from Lunati. Don't forget to break in with correct timing, inner springs removed and 20 minutes stationary at 2500 rpm, keep motor cool, then shut off. Install inner springs, set lash change oil and have fun. Use an oil like Driven for break in. See pic for specs. $350 plus frt from Houston area. PayPal Preferred
Thanks FABO
Thanks FABO
