Carmen Marchesani
Just got my tires and rims mounted. 15” rims 235 70 size tires.
Me too!Can I get the rim size and offset of them?
One more number please...Rim width?15” 4” backspace large bolt pattern and they just fit!
Early A's look great with good sized 15's. Yours looks great. 15x7 with a 4" backspace fit good.
A-body 8 3/4 or b-body? If A-body, how did you get to big pattern?
Looks great, a little more backspace would have been better, but sometimes you can't get exactly what you want/need.
Gonna run poverty caps?
I’m waiting on 15” x 6” rims. BBP then I’ll do the brakes.Looks great, same size front and back?
Rear was built by a guy in Michigan. I just added the brake lines.A-body 8 3/4 or b-body? If A-body, how did you get to big pattern?
Thanks.Early A's look great with good sized 15's. Yours looks great. 15x7 with a 4" backspace fit good.
Tried to PM you, your inbox is full. Question, what source did you use for your steel rims?
I bought them from Jegs. I believe it was a 5 month wait.Tried to PM you, your inbox is full. Question, what source did you use for your steel rims?
Norm
