Bobzilla
That is the correct way to get a current SFI rated flex plate for your Magnum application. Definitely nothing wrong with your plan.
Do tell!!!I ended up making a flexplate with a template I got off I guy from this site
Bobzilla sent me the template along with the weight...great guy!Do tell!!!
A template to cut a neutral flexplate into a magnum flex plate like the discontinued B&M 10241?
So you added a weight or cut a scoop out of it ???Bobzilla sent me the template along with the weight...great guy!
How can I get a copy???You just cut out a small section of the zero balance plate.
The guy who sent the template also included the final weight of the plate in grams to verify if the amount removed was correct.
I m in the middle of building a new house and all my garage stuff is in storage... it will likely be 6 months before I could find the template...How can I get a copy???
They are different, I know that much.I don't have the 10241 for 904 trans to 360 with Magnum balance, so I cannot make a template for that smaller flex plate.
I have the 10242 for 727 trans to 360 with Magnum balance. I still have not verified if the larger 10242 will clear the starter on a 904 setup.
Bob I wonder why you couldn't use the 727 plate with the 904 transmission. I am using a 904 transmission with a 8 inch coan converter and have it bolted to the factory 360 magnum flex plate. I had to file out one bolt hole like you normally do. My 8 inch uses the 7/16 torque converter bolts. I have had my dakota running and didn't have in funny noises cranking the engine over etc. My friend had to cut the stock magnum flex plate when he had it, to clear his 727 torque converter. If you would send me a template for the 727. I am willing to try and see if it would work with my 904I don't have the 10241 for 904 trans to 360 with Magnum balance, so I cannot make a template for that smaller flex plate.
I understand that the 904 plate is smaller, but by how much? Does anybody knowBob I wonder why you couldn't use the 727 plate with the 904 transmission. I am using a 904 transmission with a 8 inch coan converter and have it bolted to the factory 360 magnum flex plate. I had to file out one bolt hole like you normally do. My 8 inch uses the 7/16 torque converter bolts. I have had my dakota running and didn't have in funny noises cranking the engine over etc. My friend had to cut the stock magnum flex plate when he had it, to clear his 727 torque converter. If you would send me a template for the 727. I am willing to try and see if it would work with my 904
If you want to test it, you need a 10230 and template of a 10242, which is the same diameter. I can send you the template. Some say it will work ONLY if running the smaller Nippondenso starter and will NOT work with the older Chrysler starter.
I cannot verify it myself because I don't have a 904 torque converter.
I saw that too.Well doing a search just now I found a place that shows having the 904 flex plate.
the http://www.performancecenter.com/item/24714-b-m-10241-sfi-approved-flexplate
Thinking about ordering one.
