Shawn Mac
My problem is the timing for a stock 1976 360 with 4 barrel. Is btdc above the zero line or below? How many degrees does each notch mean? All answers will help. Thank You
Thank you for the info. It has a new HEI dizzy. So I'm looking to be around the third line on top of the zero at idle?Above or below is ambiguous at best; advance is ccw of the zero,which if the index is on the passenger side of the engine,I suppose could be "below".
Each division is 2 degrees
There are long hash marks at the 10 degree points, and the in-betweeners are shorter.
Welcome to FABO
Be careful when setting the timing using base or idle-timing.
With a stock D (Distributor) you generally cannot arbitrarily add much timing at the bottom without having too much at higher rpms, which can damage the engine.
The whole point of having adjustable timing in the D is to have the proper advance after about 3600 rpm. But if you set it there, starting becomes difficult, and the engine may suffer detonation at lower rpms. So some form of advance reduction for idle, was invented to satisfy the engine's requirements at both ends, and the mechanical advance D was born.
You can play around with it all you want, so long as you do not exceed ~36* at ~3600, AND so long as she doesn't detonate under load. Detonation breaks parts and must be avoided at ALL costs
MAYBEThank you for the info. It has a new HEI dizzy. So I'm looking to be around the third line on top of the zero at idle?
Watching the advance. Explain please.MAYBE
What you really want to do, is, with the vacuum advance defeated, rev it up while watching the advance, until the advance stops moving, then make sure it's not more than 36*, (34* is safer for a newbe). Then adjust the timing to 34/36 at that "all-in" rpm, and return the engine to idle. Now whatever the idle timing is is your NEW base-timing
Make sense? Yes, thank you. So, say at 1000 rpm I should turn dizzy to 34 degrees above the zero mark? I do not want to sound stupid, But I AM! I have a new Innova 5568 timing light coming Monday if I can figure out how to use it.Well, you'll want a timing light hooked up, when you rotate the distributor you will see the timing mark on the balance move in relation to the stationary marks on the timing cover.
Make sense?
Thanks for all the replies! Here are some pics.Most any and all timing marks are before top dead center, and if there is any on the ATDC side, there will be very few. A pic of your balancer in relation to the timing tab would do wonders here!
In regards to the pics I posted, any ideas which line to match up with balancer at idle? ThanksAs a clarification, you can use an adjustable timing light, or a timing tape, you don’t need both. Some find that the timing tape is easier to understand.
Thanks! There is a long notch on the balancer. Just not in the pics.So that looks like a 69 and older cover, not a 360 cover, Now the CCW advance marks are "UP"!
And this cover seems to have a long hashmark at 4*BTDC; no mater. You will need the Dial-back lite OR, to mark the balancer. There is no other way..... for you.
Here is another pic that I just took showing the line on the balancer that is filled with soap stone. Also, I did not notice til blowing up this pic that there are other smaller deg. marks on the balancer. My eyes are not what they used to be.post 20 edited
So that looks like a 69 and older 318/340 cover, not a 360 cover, Now, the CCW advance marks are "UP"! And there was never a 360 balancer made to work with that cover!
That would be GREAT! Would that be a youtube thing or would you post it hereA/J, this is just wrong. That is the correct timing cover.
Shawn Mac You have the right idea. Advancing, or before top dead center, is up in the pictures. If you'd like, I'll make a video and post how to set ignition timing.
I will upload it on youtube, and post it here. Got a couple things to do, then I should have it uploaded and posted right here on your thread in a couple of hours.That would be GREAT! Would that be a youtube thing or would you post it here
