Megatron said:
Denny, Just checked out your posting, all I can say is WOW :notworth: That is a beauty. Let me know if you ever get down this way, it will be a pleasure to meet you someday.
Later...Steve
Thank you.....................
The green '73 Hemi Duster is now owned by a fellow in the Akron - Canton area.
(maybe you'll see it around).
I guess he's making some changes to it........I sure hope it doesn't show up with
spoilers, hood scoops, stripes and T-tops with N-50's sticking out of the rear wheel
wells........I worked real hard to keep it clean and to have everything
fit with a flat hood and 275/60-15 Drag Radials tucked nicely inside.
.........Oh well.......It's his car now..........
BTW....that car has a Feather Duster hood and deck lid with the aluminum
webbing. The front bumper had an inch cut out of each end before rechroming
and was also mounted back closer to the body as well, on custom brackets.
The large rubber guards were removed (this is not seen in early photos).
These are subtle changes that make an enormous difference when parked
side-by-side with another '73-'76 Duster.
