rastaswinger
Active Member
- Joined
- Oct 2, 2005
- Messages
- 29
- Reaction score
- 0
allright folks i have been searching all night through posts and i am still confused so i apologize ahead of time if this has been covered. I have a 1970 dodge dart and it has a slant 6 in it and i have been looking around for a car with an engine and transmission to swap right in. i have found a bunch of cheaper mid 90;s magnum 318 vehicles jeeps/vans. to bolt it up i am assuming i still need the motor mount kit. would the transmission from a van work in my car or am i going to have to modify the floor. i know a jeep transmission wont work due to the transfercase. so can i basically just drop in the magnum with the EFI and computer with van transmission or would it be easier to do a carb set up, how does a carb set up on one of these run if so. what transmissions would work if the one out of the van would not. is there possibly a writeup on this. so many questions so confused, i appreciate any answers, thank you so much !
