diymirage
HP@idle > hondaHP@redline
Your welcomeThank you!
Did you figure out what bolt pattern and brakes you have?
That will dictate a lot
I agree, I've seen some really nice old mopars with 20s' but to make it look right, takes some serious forethought and design work. They need to be tucked under pretty tight and that's not easy especially up front. They are not everuone's cup o' tea but they can look good. The trick is not making the car look like it's a toy. MuscleRodShop in South TX does some very nice work. I got to see a charger they did sa a widebody before it was public. Stunning work they did and it looks "right". That car is six inches wider and 3 inches shorter that it started out and has a full chassis, and viper motor.
-C
It has 5 x 4.5 bolt pattern now. There is disc front, rear drum ... do I need any other info?Your welcome
Post a picture of the center of rear axle. We should be able to identify it.Honestly, I have no idea ... how do I find out?
LOL ... I'll take a picture tonight and post it. Thank you!Post a picture of the center of rear axle. We should be able to identify it.
I almost said 'post a picture of your rear end' but thought better of it..
U b correct!
72 Dart SwingerOk, so we know you got LBP, disc's up front, and a small rear with drums in the back...what are we working on again, 72 scamp?
Thank you, I'll check this link out. Yes, I think 15's will look the best.here is an interesting article on how to know for sure what fits
but ballpark, (i take it you want 15s?) 15X7 with 4 inches of backspacing should be fine
(of course, every car is different)
https://www.hotrod.com/articles/fit-biggest-tires-possible-mopar-body/
