BKCowGod
Hi all! I sorta made an impulse purchase last weekend and now I have a new daily driver. Base everything other than the 225 and automatic. It is essentially bone stock with the exception of some ancient aftermarket A/C and an awesome late 80's tape deck. Also not a hint of rust top or bottom. So far I have replaced the 30 year old tires (guys at Pep Boys got a kick out of installing the tires) and shock absorbers, rebuilt the carb, and made some small wiring fixes. Also replaced all the instrument bulbs with LEDs. Big item on the list is an electric ignition.
Car has been super reliable for the last week, but having charging issues - ammeter jumping around, everything showing 12v whether the engine is running or not. With the car off, turning on the headlights makes the ammeter drop. No change when I bypass the green wire from alternator to voltage regulator. No change when I toss in the big ol' Powermaster alternator I had sitting around. Big spark when I jumper the alternator. Tomorrow I plan on replacing the voltage regulator, but if anybody has any other suggestions I am open.
