Been braking in my 383 I built over winter and can tell I already am going to want to ad more power this coming winter.
Anything I can do to my current build to beef it up more? Stock valve train right now
Bore - 4.280
Stroke 3.38
Rod length 6.358
Gasket bore 4.40
Block deck height 9.960 (stock=9.980) Took .020 off
HG thickness - .039 (Felpro)
Piston to deck height - .000 to .005
Piston head volume - (-6) (KB400 .030 dome pistons)
Chamber size – 84cc (I'm using aluminum sidewinders from Mopartsracing.com *Todd*)
Total comp = 10.01:1
Comp Cam XE274H part number 21-224-4
Additional specs:
Weiand Action plus intake
Pro systems Holley pro series 4150 carb
Holley blue fuel pump (7psi)
440 source aluminum water pump (160 thermostat )
2500 stall
26” rear tires
Dana 60 3:55 gears
Bore - 4.280
Stroke 3.38
Rod length 6.358
Gasket bore 4.40
Additional specs:
2500 stall
26” rear tires
Dana 60 3:55 gears
