What are: “things you aren’t going change anyone’s mind on in an automotive Internet forum” AlexSpark plugs, engine oil, oil filters, religions, air filters…
I’d try a set of those…… with the gaskets
what about the later model heads? say, the 80's. metal ring washer or still no?The metal ring washers (gaskets) do not belong on the spark plugs—whatever brand of spark plugs—in a '63-'74 Slant-6, so are you by-the-book or not?
'75-up Slant-6 heads take taper-seat plugs, which never have a gasket.what about the later model heads? say, the 80's. metal ring washer or still no?
I was going to say, who TF uses a torque wrench on spark plugs anyways LOLI'll throw this out there for what it's worth. I believe the 30 LBFT is for the plugs with washers, so the washer gets crushed. Once you remove the washer, I don't believe I'd go down 30. I've never in my life torqued a plug down and never had issues.
