AlV
Crabs in a barrel
Now why would I wanna do a fool thing like that?
Heya Trip, , Glad to hear the clouds a clearing for ya!
fly your flag..man.
The 83 GT works damn good,as well as the 289-302 Performer.That 8" inch,is a nice swap. (3:40 gears,V6 automatics,IIRC?...). Talk low buck Ford,all you want. I like good stuff,this is good stuff. Enjoy it....
So... A 5 litre Pinto, sounds like a LOT of fun. Keep us posted.
I have that very intake.......but the ports are a good bit smaller than the ports on the heads. What's your opinion?
What are the heads,R.R.R.? Velocity is everything here,just avoid the garbage '86 "swirl port "heads....1.78/.1.45 valves .Quite frankly,you had the cam ground accordingly. Unless you have money to spend why ???????
They are the best heads Ford mead for the small block. The GT40P heads off the Exploder. That's what the whole engine is. 1999 5.0 Exploder engine.
I made a custom grind on desktop dyno. 218 and 224 @ .050 on a 110 with .482 and .506 lift. Made more torque than anything else I tried. If the port mismatch was the other way around, I would worry more, but I think since the head ports are bigger, it will be ok.
And yes, the plugs will be close, but after I grind some nasty casting flash off the manifolds, they will clear fine.
So then you think the port mismatch won't be too critical then?[/Q
Bolt it on,and tune it,remember to tin that E.G.R. port off....Seriously, a nice combination.
Thanks for your input Tim. I really appreciate it.
R.R.R,you are more than welcome. Just roll with it,and go cruise.....
I have even seen 460s in them. But, all I want is something fun to drive that gets reasonable mileage. I am gonna try one of the new 625 Street Demon 3 barrels on a stock 84 GT intake. My exhaust is limited to the mustang II manifolds since headers are costly and require cutting the car. I am having a custom cam ground from Oregon. It made almost 350 pound feet of torque with the head flow numbers entered on the desktop dyno. That should be snappy.
any pictures of this "bobcat" I would like to see that
X3Okay Rob enough talking about the F word time for pictures you show me yours and I will show you mine.
LOL
Kenny
x500000X3
:worthles:
Get R done !!!
:burnout:
