redfastback
Don't ask me... my garage is empty
i just did a conversion on my buddys coronet and did the ammeter bypass. the only bad part is that it is not charging. cant figure out why. the bat is on the trunk, 0 or 2/0 gauge from + post to starter, alt constant hot to starter, alt sense wire to constant hot stud on starter relay, alt 12v ignition source wire to wire from old regulator(ign 1) and is where msd is wired to both ign 1 and ign 2. took alt to shop and they tested it good.
any ideas?
any ideas?
