Dotchguy
Need help on this:
I have a cheater system I purchased its a dual carb
setup I want to use it on a single carb setup using one of the plates
But not sure of the diffrence in the jetting for hp levels between the kits
single and dual both kits use same plates /fuel and nitrous solinoids{ but diff jettings} obviously for the flow needs between dual and single off a single solinoid}
so what jettings/ ratio am I looking at?
