i will be running this kit Nitrous Outlet 22-80100 Nitrous Outlet X-Series Nitrous Oxide Systems | Summit Racing on an rpm air gap 418 stroker with a 1 inch spacer do i run the plate under or on top of the spacer . i am also running a progressive controller and a window switch and a fuel pressure switch and also a bottle heater and pressure switch any tips on wiring or bottle installation or any tips at all will be listened to and appreciated . Thanks .
