Well, I got the switch out and it appears to be shot .. A couple of the spades are really rusty, so I'm going to replace it .. So far, the only place I see one is at year one for $35. The female end of the connector doesn't look too bad, so I'll try cleaning it out w/ contact cleaner, and if that doesn't work I'll hit it super fast w/ my mini sandblaster .. That trick worked slick on the bulkhead connector -- looks new...
I had trouble getting my hand up there, so I loosened the bezel right up, and that allowed the switch enough play so I could push the release button..The knob itself came off first, but it seems to press back on really tight...
I had 12 volts at two of the wires inside the plug -- the double red one, an a black one w/ a white tracer..The rest showed no voltage... I'm hoping this is ok ??
Also, while I'm in there, the car came w/ a optional light kit. There's a map light toggle switch under the dash under the light switch which has been shot for a long time.. There's no power there, but hoping it's because it has to go from the headlight switch and through the fuse box first ??
Thanks guys,
Kenny
