Hyper Henry
Figured out that the pump bushing was gone in my trans that was the culprit. Re-assembled with same fiber washer on a different pump as had .062 end play before I disassembled. Now when I install and tighten pump bolts with same washer it I have zero shaft end play. What gives?? Should a try a thinner or thicker fiber washer??
