BuckeyeAlex
After washing my car (1969 Dart) last night, as I went to pull back into my garage, I pulled the headlight switch and noticed the headlights didn't come on. I've owned the car for about 2.5 yrs and all lights have always worked, so this seemed odd. FABO, I turn to you yet again.
After cleaning the connectors on the switch with no difference, this is what I've found:
-Tail lights and brakes both work normally
-Flashers work normally front and rear
-Turn signals both front and rear light up and stay lit, no flashing
-With parking lights or headlights turned on, there is no action up front. No headlights, no parking lights
I'm confused as to why the parking lights will work with the turn signals and flashers, but not the headlight switch. I'm going to check and clean the grounds this evening, aside from that I'm thinking it's the headlight switch, but then I question why the tails would work off the switch, but not the parking lights or headlights.
I did have the grille off of it last month, but I'm pretty sure I've used the headlights since then without issue and I gave the connections a quick look last night and they seemed fine. Headlights have only ever been disconnected once last year when I had to replace one that was burnt out.
