No heat
Ricki01
Member
Georgia
I’ve got a 97 dodge 1500
Just replaced all hoses thermostat and heater core. When I put the heater core in I bent the side of it. Would this cause it not to have heat now? It didn’t have heat before either. The blend door and heater motor are working. I’ve also burped the system. Any help please? Thank you
It sounds like there is a flow blockage...
Check for flow through the heater core... Run a hose from one side and see if it come out the other...
