74Dusted
Stock Piler of 340's
went to bench test my A833 on the floor, I can row through all 4 gears with ease, but when I try to shift into reverse, there isn't one (on the shifter at least, i can engage it at the transmission by hand)
A Hurst Comp Plus shifter mechanism (for an A833), but it only has "2 rows" to the shift pattern, 1st/2nd and 3rd/4th. I can't slide it over any further (over and up/beside 1st gear) to grab reverse, it's just not there and it won't move past the 1st/2nd row. Shifter moves freely though, cleaned it up and sprayed it with white lithium grease thinking it was a lubrication issue. no luck
Tried pushing down on the shifter and sliding over, nope, still goes into the 1st/2nd row. Tried pulling up on it and sliding over, nope, still goes into the 1st/2nd row. The reverse arm hanging from the bottom just free floats if you disconnect the linkage.
I'm lost on this and it's got me pissed off like you wouldn't believe.
