kempkan
I tried disconnecting the tach and speedo again and the coil is getting very hot just with the key on.
Ok 4.2 to the + side of the coil and 1.5 to the - side of the coil with the ignition on. I can't get an accurate while cranking because the kid had the starter relay on push button to jump it and I haven't got that far yet with this car. Should there be power on both sides like that?
