In August I bought a '65 Dart. Owners said it had been sitting for last 4 years. It would start right up then. In mid-September on way home from brake shop it started running very rough, but I got home. Next day would turn over but not catch. After some checking I discovered gas had gone bad and tank very rusty.
So I replaced tank, sending unit and one of the fuel lines. Cleaned out the other line. Replaced filter. Finally yesterday I put a couple of gallons of gas in tank and tried to start her. Won't catch, will turn over very willingly. I can see fan turning as I try to start it. Fuel to filter, which is just about 6 inches before carb. Fuel at carb as I back off fuel line at carb some gas would leak out. Had wife pump the pedal yesterday, looked like fuel coming in carb itself. I could see fuel coming in.
So what's the problem?
Plugs need cleaning/replacing?
No spark?
Carb fouled up from running that bad gas/varnish?
Busted timing belt?
What would be a good thing to check next/now? Never done any of this so some wise help would be deeply appreciated!
Glenn
P.S. Am not lamenting changing the tank, etc. That was sorely needed anyways!
No spark?
Busted timing belt?
Glenn
