Aloha!!
Ok this probably sounds stupid... but if you have a tapping noise coming from your valve train. AND you have non adjustable rockers. What can or do you adjust? I have a 340 that has some play on the #5 cylinder exhaust valve rocker. I didn't take any measurements...just was able to move the rocker slightly. The others were firm on the rods.
If I do have play on the push rod...do I replace the rod? lifter? rocker?
If I do replace a lifter..do you always change them all or just the one...
I'm not going to take this on myself but I want to understand the process.
Mahalo in advance for your inputs!!!
