[SOLD] NORS ECU's
halifaxhops
It's going to get stupid around here!
Hoppyworld, PA
Located some more made in USA real ECU;s, boxes are trash and wont be shipped. All tested fine. Asking $45 shipped lower 48.
@halifaxhops why did some vehicles have 5 pin or 4 pin, with the single & dual ballast resistors? Can I swap a 5 pin dual ballast to the 4 pin single ballast resistor?
67Dart273FABO Gold MemberFABO Gold Member
47,701
15634
Oct 14, 2010
Idaho
Local Time:
1:20 PM
The only difference in the circuit / ECM with the dual ballast is that the second ballast resistance feed power into the 5th pin on the ECU. That is no longer used, and unless you find a really old original vehicle or really old NOS, most any new ECU WILL be 4 pin.
You can use a 4 pin box in a 5 pin harness, but not the other way around
Incidently, the "single" (or other half) of the ballast is the same exact circuity/ wiring as the old points setup. In fact in an emergency, if the thing quits, you can stuff in a breaker point dist. hook the wire to the coil, unplug the ECU and go
In today's Chineseoficianicated products, hard to say, but ECUs usually don't fail that often
