rigger3006
i have nos lifters new in box from the 80s, before i started install today i pushed down on plunger, they wont move, is this normal? i wasnt going to prepump them with oil, just seeing if there was any movement
The cosmoline or golden colored mopar lube binds them after years sitting...they should be fine once oil wet and up to temperature.i believe i was overthinking it, i installed 2 lifters and tightened down rocker shaft and of course the plungers went down
