I wonder if the head bolts are bottoming out? The block looks to have been milled. The head bolts bottoming out could certainly cause that. Also, trash or even a small bit of water or other liquid in the bottom of the bolt hole could even cause it when the bolts are torqued down. I've actually not seen that before. I agree after seeing the picture. I wouldn't use it, unless I had no other alternative.
