68 HEMI GTS
Still plugging away! Checked P/V in a few different cam installs to see what options I have. Cam calls for a 110 install. 106 would be max, that puts me down at .090 on the intake. I plan to run it at 110, just wanted to check it incase i don’t like it at 110. Installed a gear drive, that was pretty straight forward once once you get the lash set. It was used so I had to buy some parts for it. Luckily I ended up with 2 sets of dowels. One set wasn't machined correctly and would have caused a huge headache. I might not figured that out without having the other set to look at.
