Not sure this intake will feed 600 hp
You might make 600 with that intake.....
with a pair of 150hp plate units under the carbs.....
maybe.
I really think those carbs are negative HP carbs.
Dude oughta consult with some folks before he buys stuff especially that because it wasn't cheap
Just saw: EQ has a set on new CH318A magnum heads drilled for the LA manifold bolt pattern that flow 227 CFM @.500 on intake
Under $900
Where did you find those?
I just rebuilt a set from Clearwater I think, be careful if they have longer valves than stock you'll run into much more than you want.
If they're stock valve length then that's good.
That's not a bad price.
