22dog22
this is a fresh rebuilt 318, comp. cam, hi dome pistons,had a issue with a rebuilt holley 600 cfm duel pumper carb, which I had posted here, I think I have taken care of the carb problems , I think, does not leak fuel any more, set fuel float level, adjusted the air/fuel mixture screws, got engine to idle a little better, I can not tell if I have a miss or some other carb problem engine will not hold an idle checked for vacuum leaks since I have an aluimuim manifold, sprayed carb cleaner around did not change the engine condition, have a none mopar electrionic ignition system with out a resistor block [needs full 12 volts],how do check for a misfire ? to rule out the ignition system. or how check out the carb more?
