DARTLARRY
I Have A 360 With A Bad Wrist Pin, Would It Be Possible To Pull The Rod And Piston And Replace Them With Out Going Through A Whole Rebuild? I Can Drop The Pan While It Is In The Car. Push The Piston Out Through The Top, Then Slide A New Piston And Rod In, Install A New Bearing, Set Pan And Hopefully Be Done. I Dont Have Much Experience In This, Can This Be Done? Or Should I Rebuild? I Will Later. But Will This Get Me On The Road For Now? Or Should I Rebuild Now And Save Motor From Further Damage.
Thanks In Advance
Thanks In Advance
