Novice racer on dirt track seeking some advice
wam9797
Member
Savannah GA
I have a 73 Duster with a 318, torque flight 727, 8.25 rear end, 360 four barrel intake, with holly 600cfm carb. I just finished my first season on the dirt track. I am looking to build up the car over the winter with some limitations. I am looking for any advise on how to keep my car stock but get every bit of horse power out of it.(yes i know that the four barrel did not come with it but got it ok'd by the track.) I am all ears so if you have something let me know.
:burnout:
Glad you kept it wheels down.
There should be people that can give good advice, I know people who race in the stock eliminator class make good power out of a "stock" engine.
We need more engine info.What are the rules? Vacuum rule? Cast iron intake only? Do they P/G pump? Chassis setup? For us to help you,what are the rules and boundaries? Please more info,not many circle track mopars(that I Know of).
The following are rules from my track, they are more like guide lines but need to stick close to them. There are no vacuum rules and cast iron intake only. Not too sure what p/g pump is please clarify? Chassis set up is all stock with leaf springs and shocks in the rear with shocks and torsion bars up front. Don't have sway bars but might put one in. If you need any more information let me know.
I have a real big issue when i am racing through a turn and hit the gas the right rear part of the bumper squats to the ground and grabs the track.
Cars must be strictly stock. Complete bumper to bumper steel unibody must be retained. No cutting, chopping, channeling or shortening allowed. The only inner body panels that may be removed are the roof and both doors to allow for roll cage installation. All other inner body panels must remain intact. All doors must be welded shut. The steel stock unaltered floor pan, fire walls, trunk (except where fuel cell is located). Front fender wells may be removed. Dashboards are required, but may be replaced by steel or aluminum. All front and rear firewall holes must be sealed off with steel sheet metal to fully enclose the driver’s compartment. Rear seat shelf must remain intact or replaced with stock appearing steel sheet metal. No aluminum allowed (except in dashboard replacement). No holes in the hood. Hood pins may be installed. Trimming of wheel wells allowed for tire clearance (2” maximum).
Suspension parts must remain absolutely stock for that make and model car. Except for front spring allowances noted in suspension rules below. No spacers, lumber, chains, etc. may be used to alter the stock suspension of that car (even if the factory installed it). Stock or stock replacement shocks only. No air shocks, load levelers or racing shocks allowed (even if the factory installed them). All rear springs must be stock and unaltered. Rear springs must be the same height/same length, same wire/bar size. No modifications to the rear springs are allowed. All front springs must match (left and right) exactly. Front springs must be the same height, wire size and spring rate. Height of the springs must be within one inch of the factory stock dimensions for that make and model car. Spring rates may be checked to be equal.
THE ENGINE MUST BE STRICTLY STOCK FOR THAT MAKE OF CAR and in it’s original mounts. No high-performance engines allowed. The only legal engine sizes from each manufacturer and the engine specifications are listed in these rules.
Engine sizes are interchangeable within manufacturer’s lines. Engine parts are not interchangeable between different size enginges.
Engine may be .040 over bore plus wear. Cast OEM replacement pistons only. No performance or lightweight pistons allowed. Only factory stock intakes and exhaust manifolds are allowed. No porting, polishing or grinding of any kind allowed. Repaired engine parts must be removed.
Factory balancing only. No grinding or balancing of pistons, rods or crankshaft allowed. Oil holes can be chamfered.
No high performance heads allowed. Stock valve jobs only. No angle valve jobs allowed. Oil shedders may be discarded. Steel or bronze valve guides may be used. Rocker arms studs may be pinned.
No grinding, altering or removal of any casting numbers, marks or part numbers on any part of the engine, heads or manifolds is allowed.
Ignition system must be OEM stock. Coil, modules, etc. must be stock or OEM replacement.
Carburetor must be stock or OEM replacement. Removal of choke butterflies is allowed. No other modifications to the carburetor are allowed. No adapters or spacers allowed. Double spring return is recommended. Fuel injection models may use track approved OEM carburetors and intake to replace fuel injection system. Fuel injected allowed but must be stock for make and model. No modifications allowed to the fuel injection system.
Stock timing chain only. No buttons or multiple key ways. Double roller is allowed.
Any hydraulic camshaft with a maximum lift .480. Stock or OEM replacement lifters only. No anti pump ups, solid, roller, mushroom cams or lifters allowed. No cross fire cams.
Optional engine equipment – valve covers, air cleaner, engine fan, oil pan and radiator only.
Good read.. page 22
http://www.hamtramck-historical.com/ama/_1973AutomobileManufacturersAssociation-06.shtml?load_img=6
A38 Police Package
In 1976, the Dart was offered with a police package, with production code A38. The A38 Dart had the highest-specification components and systems throughout, including a heavy-duty suspension with a rear sway bar and firmer shock absorbers, larger brakes with semi-metallic front disc pads, maximum engine cooling, and high-capacity alternator and battery. The engine was Chrysler's 360 cu in (5.9 L) LA V8, with an A727 TorqueFlite transmission. Police-specific equipment such as a calibrated speedometer and high-intensity dome light were standard equipment, and an A-pillar spotlight and push bars were optional.
340 suspension will really tighten the car up and front and rear sway bars will let it bite the track.
They didn't say anything about squaring up the block and making the head surface true... Just you needed to remove .030 to get the head straight. . . depending where your piston is in the bore will determine the squaring you need
look and see who has the lightest replacement piston. . .
Don't put pics of your car here so no one will know what you're doing. . .
I would ***** about the F.I. rules , if they are allowing F.I. motors then are they making people pull the rollers. . .
Then you might want to get a mag motor, there rollers are better than the la's factory flat stuff. . .
As for the handling issue.... they don't want you doing anything, find factory sway bars and mount them without rubber bushings, find nylon and use nylon. . .if you have to machine it to work, do it. Same with the rear spring eyes as for the front control arms and being in dirt might not need to do the nylon there.
Oh yeah and by the way im the only Mopar at the track which is great because all of the people that would say anything about my car are Ford and Chevy racers and know nothing of dodge.
My buddies and I did one season of dirt track. It's hard being the only Mopar out there! We used a longer spring shackle on the passenger side, but it looks like they might call you out on that. You could ask them, though.
A P/G pump checks for swept volume and compression.If you have already run a year here,don't sweat it.If you can swing a Magnum swap,the efficent heads/roller make it worthwhile.As for a E58 engine,basically a 4bbl 360 with a 340 cam and double roller chain.
