just to help on some question
the star shape brackets are from 1965 to 1969
the D shape brackets are from 1970 to 1972
so if you are using a 71 disc brake set up on your 66 car, you will need the 65 to 69 brackets.
if you are using 66 disc brake set up on you 71 car, you will need the 70 to 72 brackets
Could you use a 71 hose on a 66 car and not swap the bracket if the setup you have is the d shape? Or will the frame bracket then be different also?
