DusterBoy15
THE WISE(guy) MEMBER
i dident see if its a dished piston part
I always run the highest octane I can get at the pump (93), simply put, it's just better for any engine, as it's a cleaner burning fuel, and you get better mileage out of it. So why not? The cost difference is minimal, and likely cheaper on the long run, due to carbon buid up and other effects of cheaper fuel. I love octane:drinkers:
Chuck has this exactly correct. I tune my 11.5 to 1 383 for max power including the maximum initial and total advance that the combination will handle and through just this kind of experimentation I was able to determine that 5 gallons of purple per tank of 93 is exactly what I need, no more, no less.The easiest way to find out what octane to run (because there are so many variables) with say 10:1 is build your engine the way you want. Put in the highest octane pump gas you can get (if this will be a street car) and get the motor dialed in as far as fuel curve and timing curve to achieve maximum power. Now lower the octane of the fuel you put in until you get to the point of detonation then go back up one step in octane. This is the minimum level of octane that your motor needs to not detonate and will put out the most amount of power. Going higher than this minimum will not do any thing more for power output. All it will be is a waste of money and octane out the pipe.
Chuck
