racingsnake440
- Joined
- Aug 29, 2005
- Messages
- 335
- Reaction score
- 22
Does anyone know if it's possible to use the tail housing and output shaft from an OD a833 on a regular a833? I can get a van OD trans cheap and would like to use the tailhousing and output shaft to convert an A body trans for use in a B body. Obviously the gears from the A body trans would need to be switched over onto the OD trans output shaft.
Has anyone tried anything like this?
