I am looking for information relative to the good and bad points involved in the use of 4-speed OD Mopar transmission swaps into A Bodies.
I have a '72 Valiant with a supercharged 360 Magnum in it, BUT, it is a very mild engine combination, and doesn't make a whole lot of power. Maybe around 450 at the flywheel on a cool day... with 8 pounds of boost.
It makes 12 inches of vacuum idling at 475 rpm with a Hughes hydraulic roller (214/218 @ .050", with .525" lift at the valve.) VERY m9ld specs... but, drives like a 318 2bbl...
I have run a 904 with a shift kit with no hint of a problem, and was curious about a comment I saw on another forum.
I have seen several "how-to's" about installing the A518 tranny into an A Body chassis, and every one talked at length about how BIG the OD unit is and how it was a lot of work to butcher the floorpan and rear crossmember for tailshaft clearance. I understand that.
Somebody on another forum in passing, mentioned, I THOUGHT, that the OD unit's external dimensions were somewhat smaller on the A500 than the A518.
Is this actually true, and how much smaller? Is it enough smaller to make a significant difference in floorpan alterations compared with installing an A518?
I am totally in the dark, but if that is true, since a 904 stands up op the kind of abuse I put it through, wouldn't an A500 work as well?
I don't want to cut this unibody floorpan any more than I have to...
Can someone enlighten me please? I've never even seen an A500 out of the vehicle, so, I have no clue...
Thanks for any information.
Bill
Bill
