sawdust
Member
Correct dimple OE Electronic Voltage Regulator
Excellent original 1970 through 1971 electronic voltage regulators for all A, B, C and E-body mopars,
These are original regulators NOS from OE supplier bin lots as was the case for the production. The regulators have been cosmetically restored to OE correct level, fully tested on an operational charging system with an alternator, battery, and 30 amp loads. Regulators are tested for voltage output, voltage stability output, voltage output under load, and voltage after lamp load. (Others on the market are not tested or if you are lucky, only bench tested, not system tested for load and output). I have both the early style tapered flange case used before January 1970 and the later style case with a stepped flange. Each regulator comes with the correct mounting screws, and a one year warranty.
Dates available:
319, 349, 379, 439, 469, 509, 040, 070, 110, 160, 210, 260, 350, 420, 021, 091, 151, 201
$99 with free shipping to lower 48
Green Lane PA
Dates available:
Green Lane PA
